Browse Forums General Discussion 1 Apr 06, 2019 2:59 pm Hey I have 5 antenna ports in the house all with cables running to them however only 2 are getting a signal. Appears that the other 3 ports weren't connected to the antenna or splitter when installed. The issue i now face is, I have a colourbond and flat roof, so there's no manhole and I can't access the inside of the roof to see what's happening with the wires. Not sure how to go about connecting the remaining 3 ports. Cheers Re: Antenna help 4May 06, 2020 7:39 pm Mutlu Hey I have 5 antenna ports in the house all with cables running to them however only 2 are getting a signal. Appears that the other 3 ports weren't connected to the antenna or splitter when installed. The issue i now face is, I have a colourbond and flat roof, so there's no manhole and I can't access the inside of the roof to see what's happening with the wires. Not sure how to go about connecting the remaining 3 ports. Cheers Consult with professional TV antenna installer. Surely you get solution. DIY, Home Maintenance & Repair Brilliant - thanks so much for that. I didn't want to start pulling too hard on it if there was some other way it was attached, but yep, it was just the paint sticking it… 2 3159 Hi there, long-time lurker but first time posting. I've bought a house 2 and a bit years ago and last year we had some major water damage on a converted pergola area… 0 7875 Yes, unless you are in a low intensity rainfall area or the area is protected from rain. Do you have access to NCC Part 2 or can you download it? I can email you a copy… 10 12357 |
