Architrave with a separation line at the joins....what does it mean? What exactly was missing so all the architraves at home has this problem?
Browse Forums General Discussion Re: Gap at the architrave joins 2Apr 03, 2019 12:17 pm How long ago were they installed? It basically means that something has moved/flexed Re: Gap at the architrave joins 3Apr 03, 2019 12:27 pm brokenstick How long ago were they installed? It basically means that something has moved/flexed This is a new house 6 months old....and all the window and door architraves has this...so I thought they have missed something somewhere Re: Gap at the architrave joins 4Apr 03, 2019 1:31 pm Painters probably used a putty instead of a plaster on the joins, chippy may not have glued the mitres either, houses also move 30mm over there life time Got my stairs designed like this with 250mm Gap marked below. Gap is bec of 2 steps added between two landing area… 0 4872 This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well… 13 19244 2 7534 |
