Hi
I have chose 2740 ceiling height for my house and it is now 2720 after plaster work
Can some one please clear me on it
Thanks
Browse Forums General Discussion 1 Apr 02, 2019 1:57 pm Hi I have chose 2740 ceiling height for my house and it is now 2720 after plaster work Can some one please clear me on it Thanks Re: Ceiling height concern 2Apr 02, 2019 2:49 pm It was already answered in your other post. Measurements are to framing members so you will lose the thickness of the plasterboard (typically 10mm) and eventually your flooring thickness. This will be noted on the drawings somewhere. Your build is standard and you aren't missing out or being ripped off. Good luck with the build. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Ceiling height concern 3Apr 02, 2019 4:13 pm Even if it was a mistake (which it isn’t) no one would be able to tell anyway. Stop worrying about trivial matters and put your energy towards making sure it’s being insulated properly and gaps around windows are sealed etc. i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 12773 ok thanks - yes was wondering if that should have been listed as Option Three! 2 7742 |
