Browse Forums General Discussion 1 Mar 31, 2019 11:53 am Re: Paint Standard - Door Edges 2Apr 01, 2019 8:40 pm They should have planed it before any paint coating. Re: Paint Standard - Door Edges 3Apr 01, 2019 9:21 pm wagga123 They should have planed it before any paint coating. Hi Do you know from where in the building standards I can get a text to quote to the builder? Thanks Re: Paint Standard - Door Edges 4Apr 01, 2019 9:41 pm Section 12.02 of the Victorian Building Tolerance guidelines is somewhat broad in regard to irregularities in paint work. Not sure if you are in Victoria. Link: Web results guide to standards and tolerances 2015 - VBA https://www.vba.vic.gov.au › pdf_file Not sure if there is an Australian Standard reference on door construction, but There may well be. AS 2688:2017 (might be the one). Re: Paint Standard - Door Edges 5Apr 01, 2019 9:42 pm wagga123 Section 12.02 of the Victorian Building Tolerance guidelines is somewhat broad in regard to irregularities in paint work. Not sure if you are in Victoria. Link: Web results guide to standards and tolerances 2015 - VBA https://www.vba.vic.gov.au › pdf_file Not sure if there is an Australian Standard reference on door construction, but There may well be. AS 2688:2017 (might be the one). Many thanks....I am in VIC Re: Paint Standard - Door Edges 6Apr 01, 2019 10:10 pm wagga123 Section 12.02 of the Victorian Building Tolerance guidelines is somewhat broad in regard to irregularities in paint work. Not sure if you are in Victoria. Link: Web results guide to standards and tolerances 2015 - VBA https://www.vba.vic.gov.au › pdf_file Not sure if there is an Australian Standard reference on door construction, but There may well be. AS 2688:2017 (might be the one). Thanks. Got it on sec 8.06: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 920 was enough to get the furniture in. We live in a pretty safe area and it’s great to see people walking to the front door. We’re not too fussed about people… 4 1404 What we have done in a few theatres ( including my own) is run 2 layers of 13mm gyprock, but sounds insulation especially for the bass is really tricky as a lot of that… 4 2578 Thankyou so much 😀 I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK 😀 2 7171 |
