Browse Forums General Discussion 1 Mar 25, 2019 3:40 pm Hi Everyone, We are halfway through a knock down rebuild and our alfresco area is a lot higher off ground level than we anticipated. We knew it wouldn’t be flush off the ground when you walked outside but now that we have seen the slab it’s a good 1.5m higher. Has anyone been in this position and designed something nice to connect the ground (lawn) wirh the alfresco? I’m looking at cathedral style timber steps off the side so we can bave a large table and chairs etc. Has anyone done something similar and can share photos and or ideas? Thanks a lot! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Alfresco a few metres off ground level 2Mar 30, 2019 6:12 am Karolien123 Hi Everyone, We are halfway through a knock down rebuild and our alfresco area is a lot higher off ground level than we anticipated. We knew it wouldn’t be flush off the ground when you walked outside but now that we have seen the slab it’s a good 1.5m higher. Has anyone been in this position and designed something nice to connect the ground (lawn) wirh the alfresco? I’m looking at cathedral style timber steps off the side so we can bave a large table and chairs etc. Has anyone done something similar and can share photos and or ideas? Thanks a lot! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ How high off the ground should it be according to your plans? Can you put a pic up of the position on the block? Re: Alfresco a few metres off ground level 3May 30, 2019 8:26 am Hi Karolien123 Here, you will need to make adjustments to the design The Council may also require engineering Drawings Projects to do after handover hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Hi guys, I want to do some floor levelling before laying the planks and am considering doing it with self-levelling or yellow tongue PB board. I am wondering which one… 0 6529 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11731 Hi, I'm new to this forum so I hope I'm doing this post correctly. Please advise if it's not. I've just bought my place. The inground pool has a marble lining that has… 0 13657 |
