Browse Forums General Discussion 1 Mar 18, 2019 3:07 pm After the recent heavy rain we've got a water issue in our garage.The bottom of the house is Besser block walls that sits below ground level. The run-off coming down the side paths seems to be getting between the blocks and the builders plastic that sits between the wall and the ground. It's almost acting as a funnel as the rain water gets above the plastic level. The water runs down the wall and makes its way to the floor level, coming up the edge of the wall and slab. I need to come up with a solution to cover the area so water can't get in. Excavation is not possible so I need to put some sort of capping over the top of wall and the plastic lip, thats deep enough to bury in the soil. Any of that make sense? Got any suggestions please? Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the… 0 38444 Thanks. I called VBA today and they said it was a Consumer Affairs issue, the old handball. Seems like the government organisations don't want to do their job at the moment. 2 7556 Hi, does anyone have any experience with using Trex rain escape or EPDM rubber to waterproof a deck so you have dry space underneath. Popular in the US and realize that… 0 3443 |
