Browse Forums General Discussion 1 Mar 16, 2019 10:37 pm I have a very deep storm water pit in my backyard. Concrete paving surrounds this pit. About half a meter out from this pit, I have garden beds. I want to have a water tap installed in the garden bed area. Are you allowed to have water pipes connected in the area above where the stormwater drain runs across? Re: Stormwater Pit and plumbing pipes. 2Mar 17, 2019 10:21 am This is covered under AS/NZS 3500.3.7.2.7 (j) and also AS/NZS 3500.1.5.3.6 (ii), both of which state a minimum 100mm separation. 3in1 Supadiverta. Best Practice Rainwater Harvesting using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Stormwater Pit and plumbing pipes. 3Mar 17, 2019 11:09 am ![]() This is covered under AS/NZS 3500.3.7.2.7 (j) and also AS/NZS 3500.1.5.3.6 (ii), both of which state a minimum 100mm separation. Thanks. What about the installation of an ORG in that particular area where the proposed water tap is to be made? Re: Stormwater Pit and plumbing pipes. 4Mar 17, 2019 12:06 pm ORGs are on drain pipes, not stormwater pipes. 3in1 Supadiverta. Best Practice Rainwater Harvesting using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Stormwater Pit and plumbing pipes. 7Mar 17, 2019 2:12 pm ![]() above the stormwater drain Are you referring to a storm water pipe or a surface stormwater drain? 3in1 Supadiverta. Best Practice Rainwater Harvesting using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Stormwater Pit and plumbing pipes. 9Mar 17, 2019 6:47 pm Reading it again, it doesn't make sense. Situation: 1. Stormwater Pit in backyard, 2. About half a meter out from the pit, there is a garden planting area, 3. Water tap to be installed with at least 100 mm separation in this garden area (above the underground stormwater drain pipe that the pit is connected to), 4. Can an ORG be installed in the same area as the water tap? Hi Tramy2020 Sorry to here the issues you are having with your home. I put a claim through my Home Insurer regarding Loss or damage because of 'Escaping liquid' -… 1 796 Hello . If anyone can help. I’m doing a shower Reno. I have pulled up the old tiles , am ready to start waterproofing. However I am stuck on the drain , it is an old… 0 1043 0 470 |
