Browse Forums General Discussion 1 Mar 16, 2019 1:08 pm If for example you have a leaky pipe and it caused mould to appear beind a wall or under a house and then that leaky pipe is fixed and the source of water to the moud is cut off and the wood dries out , does the mould die or does it stay there Re: moud and water 2Mar 17, 2019 12:17 am The spores will stay dormant almost forever. Mould should be properly removed and sealed, just drying it off won't help. http://www.sternmold.com/mold-informati ... -cycle.php This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28422 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8578 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20295 |
