Browse Forums General Discussion 1 Feb 21, 2019 8:02 am There is a 1000x300mm storm water easement in the top right corner of my backyard. As part of leveling the lot, current opening of that has to go 300mm down the new level. Any idea how can I do this? Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 7850 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 6864 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10486 |
