Browse Forums General Discussion 1 Feb 20, 2019 9:41 pm Hi all, this might be a really dumb question but I have no idea and no one can seem to help me.... I am trying to mount my washing line. The holes that I have drilled into the brick have hit the rod voids, to counteract this I have gone crazy on liquid nails and inserted the plugs hoping this would give enough hold for the screws - it has not. How are you supposed to safely mount such an item when you hit voids in your brick? How do you get the screws to hold? Bunnings lady suggested I get a bigger bolt and re-drill however I am limited by the hole on the washing line, so can't go any bigger on the bolt. Is there a solution for this or have I royally f*d it up? PLEASE HELP! Re: Drilling into brick - please help 2Feb 20, 2019 11:59 pm Have they only supplied screws and spaghetti? Can't you use wall anchors that expand inside the hole? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Drilling into brick - please help 3Feb 25, 2019 4:59 pm I had the same problem with the wall mounted washing line I installed. I got the longer (than recommended) dynabolts and drilled the hole through the centre portion of the brick so the dynabolt was anchoring to the centre portion of the brick. I then drilled out a larger hole on the clothesline bracket to accommodate the larger dynabolt. In my case the clothesline was a Daytek line from bunnings. I have not had any issues with the bricks or the line. I use Tramex moisture meter and it will tell me instantly if the wall is cement sheet or plaster or masonite but most people dont have the equipment. 5 7097 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11849 8 6158 |
