Outdoor Kitchen & Glass Balcony
Recently built a house with a good sized alfresco area. We intentionally left part of the alfresco uncovered as a bbq area/outdoor kitchen but wanted to put a glass balustrade around the whole alfresco as it is elevated. This would mean the balustrade would run right behind the outdoor kitchen.
Any issues with running a glass balustrade right behind the outdoor kitchen? Some glass balustrades have exploded in heat (the 40+ Degrees days) so was curious if anyone has a similar setup and has any issues.
Thanks
esanto1
I would pick a BBQ on wheels that could be moved away from potentially troublesome Building Materials
Such as Glass, SIP and PE filled materials. Apart from shattering you don't want to burn your house or apartment down
Hi I would pick a BBQ on wheels that could be moved away from potentially troublesome Building Materials
First time building 2 storey home in NSW. Below Current plan have separate balcony. But thinking to do a multipurpose lounge with balcony (kind of sunroom) in first floor…
18/07/2023
4
Well you won't get cooked by the afternoon sun when sitting out on the balcony on a summers afternoon but you won't have much to look at besides the neighbours…
16/10/2023
Dear all, Requesting your help in relation to a CDC code. We are building a new home in NSW on a corner lot (500m2, 15m wide) following Greenfield CDC code. Our design…
