Browse Forums General Discussion 1 Feb 15, 2019 2:36 pm Hi my house is 7 years old, wooden frame with vinyl cladding and steel roof. Recently a few times a day l hear a thump noise coming from inside the the roof area on the far right hand end of the house. Maybe 3-5 times a day , always the same area .It sounds a bit like hitting a hammer against wood. l was wondering if anyone might guess what could be causing it and if it is something l should get checked or most likely nothing to worry about. l read somewhere it could be the wooden frame inside the roof expanding and contracting from heat from the sun or could it be more serious or structural problems that should be checked? Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9075 Chemtrails, only the most disproven conspiracy theory in the history of conspiracy theories. You've gone in the deep end, drowned, and are now a mindless bloated… 5 86575 Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the… 0 38448 |
