Browse Forums General Discussion Re: Bracing plans 4Feb 06, 2019 8:42 am jacpat If the bracing plans for my property were engineered for aac concrete will it make a difference that eps was installed instead Yes, The wind bracing & connections should be greater for lighter and less stiff materials, I suggest you get your engineer to also check wind loading, Foundation Supports along with the framework Goodluck Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Hi all, Not sure if this is a good place for this question but I guess we'll find out! I'm a novice, building a modular room inside my garage/shed and need to create… 0 1856 Really tight at the top of the stairs- how to get furniture into those rooms? Study books - does anyone really use them these days? Large storage closet would be more functional. 2 6884 Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 13769 |
