We deliver packs of 70x35 non-structual pine all the time for roof battens - no confusion at all mate
Pergola/carport roofs do however require structual pine due to the wind uplift they are subjected to
Requirements vary state to state
Browse Forums General Discussion Re: The noggin between the studs 21Oct 02, 2008 6:58 pm ausdesign Luke was just a bit confused , roof battens are structural that's why I thought he must have meant ceiling battens. We deliver packs of 70x35 non-structual pine all the time for roof battens - no confusion at all mate Pergola/carport roofs do however require structual pine due to the wind uplift they are subjected to Requirements vary state to state Re: The noggin between the studs 22Oct 02, 2008 9:14 pm Dukekamaya ausdesign Luke was just a bit confused , roof battens are structural that's why I thought he must have meant ceiling battens. We deliver packs of 70x35 non-structual pine all the time for roof battens - no confusion at all mate Pergola/carport roofs do however require structual pine due to the wind uplift they are subjected to Requirements vary state to state Crap. The requirements don't vary state to state, they vary according to the designated wind catagory and the roof load amongst other items. Some people reading posts assume that what is said is gospel. If you don't know - don't say it. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: The noggin between the studs 23Oct 02, 2008 9:30 pm Anything written on sites such as this should always be double checked and verified - trust me I've seen some of your posts
Take a chill Re: The noggin between the studs 24Oct 02, 2008 9:52 pm I'm chilled.
But as you've noticed I feel strongly that 'the average person' reading posts on this, and any forum, can assume that the information given is correct and will take that information as a part of their decision making. List the posts that I've made an incorrect reply to and I'd be more than happy to rectify the information given. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: The noggin between the studs 25Oct 02, 2008 10:02 pm Pete I apologise, that wasn't called for.
Not sure what the law is in other states, in NSW you can't do structural roofing work (carports/pergolas excepted) without a builders/carpenters licence anyway. I found that strange when I obtained my O/B licence that I was allowed to build wall frames internally and vastly modify loadbearing external wall frames but not put trusses on top of them Re: The noggin between the studs 26Oct 02, 2008 10:09 pm Done Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: The noggin between the studs 27Oct 03, 2008 9:23 am Point taken on the electrical cables. As I said, that was just an assumption on my part. Makes sense too.
I have seen him using the yellow tongue to get down the gaps of a wall to run an antenna cable down. How do electricians run cables down an existing wall, does anyone know? Re: The noggin between the studs 28Oct 03, 2008 1:16 pm Mel&Em Point taken on the electrical cables. As I said, that was just an assumption on my part. Makes sense too. I have seen him using the yellow tongue to get down the gaps of a wall to run an antenna cable down. How do electricians run cables down an existing wall, does anyone know? In a timber frame house they drill a hole thu the top plate. If they gave to get go below a nogging, they can either use a long spade bit, or with a long pole, knock the nogging out Best Price Wardrobes Sliding door robes | Walk in robes Deco panel | Mirror | Melamine 26 to 28 Cottage lane Hackham M: 0402 927 376 http://www.bestpricewardrobes.com.au Trade welcome Re: The noggin between the studs 29Oct 03, 2008 2:01 pm Kevin Brown or with a long pole, knock the nogging out Yeahehe.....great especially if the plasterboard is attached. And guys next time you blame an engineer or building designer for being conservative in their design it's because they have to take into account this sort of sheer butchery over the life of the building.... Re: The noggin between the studs 30Oct 03, 2008 5:25 pm to_do_list Kevin Brown or with a long pole, knock the nogging out Yeahehe.....great especially if the plasterboard is attached. And guys next time you blame an engineer or building designer for being conservative in their design it's because they have to take into account this sort of sheer butchery over the life of the building.... I'm only telling what I see getting done, I dont do those sorts of things myself The other (better) way is to notch out the timber thru the plaster board, and patch up after. Or in brickwork chase and patch the wall after The customer is the one that dictates how its done. If they want it done properly the sparky does it the hard way and charges acordingly Not everyones home is like the pictures on this forum There are some areas where they only call a sparky because they absolutely have no choice. They dont care what the end result looks like, as long as they can have the fridge or whatever working again Best Price Wardrobes Sliding door robes | Walk in robes Deco panel | Mirror | Melamine 26 to 28 Cottage lane Hackham M: 0402 927 376 http://www.bestpricewardrobes.com.au Trade welcome Old Home Restoration / Renovation To reduce noise transfer without compromising the aesthetic of your exposed I beams, consider filling the 100mm gap between the I beams and the floor above with dense,… 6 9112 The engineering is the engineering. It's irrelevant how much material you have. Unless it fits the requirements of your design the engineer can't "make"it work. You might… 7 9656 |
