Found old stormwater pipe - what to do?
I know that it comes from outside my property (it is definitely not connected to my house) and discharges at a point out the front of my property.
I can make an educated guess as to what house it is coming from, but don't know for sure. Council are not aware of the pipe so are not any help. Are there any recommendations on what I could to try find out for sure what house the pipe is connected to?
I'm trying to find the house the pipe is connected to so I can do the right thing and tell the owner what is happening.
Who would you suggest I talk to about doing a pressurised smoke test?
I wouldn't be planting a tree over the pipe though. Tree roots create high matric suction which can lead to ground movement.
Thanks for your reply.
I understand how planting a tree over a sewer pipe that goes directly into the house could cause ground movement. However, if the tree is planted over a stormwater pipe that is coming from a house potentially 50 metres away, unless the tree was an established eucalypt or something similar I would have thought the potential for ground movement for both my hour and the house 50 metres away would have been minimal?
Pipes usually crack at the joins which is concrete in the case of clay pipes. If it is a stormwater pipe as it would appear to be because the exit is at the kerb, it won't be far under the surface but you have already seen it and know the depth. If the pipe isn't in use, then you could I assume rip the pipe up but if it is in use, then I would be hesitant to plant a tree on top of it but at the end of the day, you are the one who makes the decision.
3
Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know.
1/04/2024
Hi All! I have engaged a plumber to re-do the stormwater drainage system on my property which is mid-70s and had blocked/cracked clay pipe drains. The works has…
2/04/2024
1
The significant date is when receive final payment invoice Check that section of contract Bit of fluff by builders prior to that
