Browse Forums General Discussion 1 Jan 31, 2019 3:35 pm We built with Coral and moved in almost a year ago. We are looking at building a pool and have just found out the pipes that run from the house to the street are 2 m away from where they say they are on the plan. Does anyone know if we have any ability to push back and get them to move them at their expense as they don't match the plans? Re: Plumbing pipes to plan 2Jan 31, 2019 5:51 pm Downpipe and stormwater pipe positions are most often nominal and it is up to the plumber to decide where they should go. I would say that you have two chances...Buckleys and none but you can only try. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. 4 5087 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5699 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10799 |
