Browse Forums General Discussion 1 Jan 24, 2019 3:27 pm I have a heap of concrete pavers (23 x7 x 5) and would like to make a raised garden bed with dimensions 2.2m x 1.2m and about 35cm high. I've asked some friends about this and they give mixed opinions. The ground where the garden bed is to be located is level. If I dug a trench and put in cement of about 100 ml deep and two courses of pavers - and then from level ground laid 5 layers of pavers - will this work out OK? Re: Can concrete pavers be used to build raised garden bed? 2May 08, 2019 7:48 pm Yes, concrete pavers be used to build raised garden bed. Those span tables can be pushed a little for a low deck if you dont mind a little flex. Last deck I did, I pushed it a little and it was still rock solid - no noticeable… 6 13765 there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18300 |
