Browse Forums General Discussion Re: Building pool near easement 2Jan 05, 2019 3:43 pm In Sydney you fill in a tapin form http://www.sydneywater.com.au/tapin/index.htm if it is too close to the easement they will send someone out to peg out the area. The staff are very helpful if you have questions You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17154 Our standard double-glazed window is tested to achieve, Rw 34, and can be glazed to suit Rw 39. The price is good too... 3 9471 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16145 |
