Browse Forums General Discussion 1 Dec 10, 2018 7:16 am Hi my house is 7 years old and has vinyl cladding, the other day l removed a piece of vinyl cladding to see what was behind, l was expecting there to be plastic sheeting beind the cladding protecting the wall but instead the was sheets of Polystyrene . Is that waterproof ? is that good protection or should there be plastic sheeting instead? my second question is l get quite a few spiders and spider webs in the corners of the cladding, l was wondering should l spray the cladding with insect killing surface spray every few months to kill spiders and insects, can insects do any harm if they get behind or between the cladding and the wall, or would that be a waste of time and just cleaning it and hosing in down regularly would be good enough Old Home Restoration / Renovation Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts 0 9484 I might be misunderstanding.... but I would be more inclined to cut a section out from the cinder block wall and place the cistern in the cinder block wall. Very messy job… 1 1281 Hi l plan to install a self adhesive vinyl plank floor. l first need to attach masonite boards underlay to by plywood subfloor of my house. What size nails and how many… 0 8615 |
