Browse Forums General Discussion 1 Nov 29, 2018 9:15 am WA Construction falls to Lowest level on record Now's a Great time to consider Building or Renovating in Perth I will be sharing a few up coming projects Highlighting Building Information Data and how the Battlers & Punters can get the best out of their projects Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17551 they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 6601 interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing… 13 46980 |
