Knockdown & Rebuild vs Renovation
Page 3 of 3
This process has become popular in unit, high rise and commercial projects, Clients & Developers love it, builders and trades loath it, as prices get screwed down, either way make sure the build is properly inspected by your engineer. hth
Have u asked for more quotes? Your build sound expensive.
Mscat, do you remember the model? We won't be looking to build an ensuite for every room in the house. But we are aiming to have 6 bedrooms .
I'm building with a custom builder (Como Homes) myself in VIC. All of the custom builders (except Latitude 37) quoted me in the region of $15-16k per square, all up. Which is why I think your quotes of $800-900k seem a bit excessive.
Have a read of my brief reviews of the 4 custom builders and the 1 volume builder I had approached: viewtopic.php?p=1828658#p1828658, and maybe one of them will suit you too.
Hi,
How much did Latitude37 quote you?
Hi,
Sent you a message
SCOPE OF WORK:
Based upon the above-mentioned communication and the supplied drawings, the scope of works, and basis of our Lump Sum price for the Geotechnical Investigation and Structural Engineering Design is as follows:
ENGINEERING SERVICES.
GEOTECHNICAL INVESTIGATION
Site Investigation and Report on the following:
• • Three (3) boreholes to 1.50 - 2.0 meters deep.
Note: - That a geotechnical site investigation re-test may also be required following demolition works.
Client is responsible to identify, on site, the location of any existing underground utilities or services. A plan shall be provided to this office, upon acceptance of this quote, clearly identifying locations on the site where soil testing can be safely undertaken. Alternatively, a specialist service locator can be engaged at additional cost to locate any utilities or services.
NB: <ENGINEERING FIRM - NAME REMOVED> will use its best efforts to avoid any utilities or services on site but accepts no liability whatsoever for any damage and subsequent repairs that may occur if:
• • Soil testing is carried out in the locations indicated on the above client supplied plan or
• • The above plan is not provided or
• • A specialist service locator is not engaged
STRUCTURAL WORKS
Design & documentation of the following:
• • Slab Design (Waffle or Raft).
• • First Floor Framing Design.
• • Roof Framing Design.
• • Wall Bracing Design.
• • Structural Certification for all structural components listed in scope of works.
For the purpose of this proposal we have excluded from the scope to be undertaken by <ENGINEERING FIRM - NAME REMOVED>, the following:
• Any works not specifically noted in scope of works
• Waste management plan (WMP)
• Stair Design
• Front Fence Design
• Pool / Spa Design
• Civil Design
• Soil Testing and Site Classification
• Issuing or any works regarding forms 3 & 4, including any required documentation
• Planning approval or any changes to planning approval requirements.
• Pier protection barriers/collision walls unless specifically noted in the scope of works
• Lighting structures and signs structures unless specifically noted
• Hydraulic analysis unless specifically noted in the scope of works above
• Existing structures unless specifically noted in the scope of works above
• Existing structures geometry and level checks
• Review of electrical circuits/programming and the like
• Review of existing & proposed utility services
• Acoustic modeling/review
• Construction staging (unless specifically noted)
• Inspection or certification of the constructed works, as constructed drawings
• Specialist construction techniques
• Checking proprietary items
• Site inspections or construction supervision, except as noted
• Variations arising from changes to the architectural requirements
• Energy Efficiency Assessment
• Fire Service Design
• Design of floor and/or roof trusses
Please note that this office, upon request, can provide a separate fee proposal for the items listed above.
3. METHODOLOGY
The following methodology will be adopted in undertaking the above scope of services:
• • Conduct the associated SOW detailed design in accordance with the requirements of the BCA and associated standards.
• • Our offer is based upon <ENGINEERING FIRM - NAME REMOVED> being provided all relevant design documentation such as architectural plans, MOCS outputs which can be relied upon to not change or require further significant design development.
• Upon being appointed to the project <ENGINEERING FIRM - NAME REMOVED> will initiate structural design documentation to concept phase. • Hold point – client to approve concept design documentation.
• NB: Any changes to the concept design caused by the client, architect, building surveyor or any other client control consultant, following hold point release of the concept design by will be considered abortive work and <ENGINEERING FIRM - NAME REMOVED> will require a variation approval prior to proceeding with additional work.
• Following the approval of the “concept” design, <ENGINEERING FIRM - NAME REMOVED> will develop the design to an ‘Issued for Construction’ Stage.
• • A, <ENGINEERING FIRM - NAME REMOVED>, independent Engineer will check all structural design elements, which provide the basis for certification.
4. DELIVERABLES
Deliverables to be provided by <ENGINEERING FIRM - NAME REMOVED> include:
• • One (1) PDF copy of the written site investigation report, including bore log of soil conditions, site sketch and allowable soil bearing capacities with recommendations for new footings.
• • One (1) PDF copy of all Structural Work, Documentation including structural design certification in accordance with BCA requirements.
The problem is builders don't wish to pay an Engineer for those items ie Structural Trusses, Structural Floors, Fire services?
I would have thought with all the problems Victoria/NSW are having with Flammable Cladding (about to bankrupt those states), Here
Stalemate leaving fire-prone ticking time bombs around Australia
Engineering Inclusions for details, Inspections, Compliance checks... etc should be increasing... not decreasing
OT, WA has the best Engineering Checks and Certifications systems and the least number death trap apartments
1
if the original house is in good condition most of what you listed could be added in stages without the need for KDR and costs and disruption of having to live elsewhere…
25/05/2023
Hi We have finally decided to complete a KDR on our corner plot in NE Melbourne suburbs. Given its a corner plot approx. 400 sqm just a standard design may not fit the…
18/01/2024
1
multiple occ properties are always billed by trades at a premium, rarely per sqm for the lot. You either have trades you know whoe will do by sqm or youre going to get…
