Browse Forums General Discussion 1 Nov 07, 2018 7:06 pm Hi I noticed that my stormwater inspection pipe is having water stagnate in it at a higher level than the ground. The inspection pipe is at the boundary of the property where it connects to the council stormwatwr main. I would thought that if no rain they wont be any water there. Anyone can comment? House is still under construction. Re: Stormwater inspection pipe. 2Nov 07, 2018 7:52 pm Sounds like a blockage to me. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4835 Hi All! I have engaged a plumber to re-do the stormwater drainage system on my property which is mid-70s and had blocked/cracked clay pipe drains. The works has… 0 18686 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8454 |
