Employ Builder on Hourly Rate?
RydeReno Welcome to the forum
Seriously I wouldn't go down that path
Plan the project properly, work out how long it will take and get a fixed price for each element/trade
BTW Some photos would help
Cheers
Hi Seriously I wouldn't go down that path
Cheers
What's your reasoning for not going down that path?
Are you saying I'm likely to come in cheaper if I get a fixed price for each trade? I'm not owner builder, and I do have a full time job, so my availability to run things would be limited - me helping out on site would mostly be weekends.
Work is often delayed during construction and you won't know that while you are at work
Also you don't want to be charged for times trades aren't there working,
I apologise for not being that trusting
Does anyone else have any experience working with builder on hourly rate? And how did it go/turn out in the end?
You won't be able to properly control what they are doing and how quickly, therefore, hourly rate will be a problem for you.
Also, builders do not charge hourly rates, they charge margin on top of labour and materials provided by their labourers/tradies.
You would only know the true margin if you go on a cost plus contract arrangement (aka open book) with the builder.
But he had a very good trusting relationship with the builder.
I can see the advantages, but personally I wouldn't do it unless I trusted the builder implicitly
Good point, The quicker the trades finish the quicker the builder gets his profit margin
Quick unskilled trades often take short cuts, leave things out, the work is non compliant and some builders don't seem to care.
Plan wisely as you will need to be on top of it, Forewarned is forearmed..hth
Try 3D Sketchup or 3D BricsCAD Shape
please post up a model so I can help with data and planning
Knockdown and rebuild upgrade Costs
Cheers
Chris
I understand the trust issues, possibilities of open cheque. But even with fixed contract, how fixed is 'fixed', and no matter which route, there is the possibility of builder employing labourers/unskilled tradies.
The guy I might be using is a carpenter/builder, so will be doing the framing himself, but being the builder and using his contacts for the other trades.
I already have other 'fixed' quotes to compare. So if I do the research and find out 'time for excavation', 'time for foundations', 'time for rough plumber/sparkie' etc - I should be able to work out whether his hourly rate is going to come in under or over 'fixed price - correct?
Plus this isn't as complicated as a full construct, as I'm only getting him to take it to 'Lock-up' stage.
RydeReno
No, Your build is not complicated it's "Click & Drop"
LOL, I saw complicated the other night at the Optus Stadium BIM Presentation
Where Engineers were 3D scanning onsite, designing and robots fabricating components in china..all at the same time
Planning,Data & Optimisation was the key
9
Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out…
7/05/2023
2
The HIA contract, in the term & conditions section states that "Commencment" is deemed when the drainage is started or the piers are dug or the slab is formed up (incase…
