Browse Forums General Discussion Re: Need advicesssss 5Oct 03, 2018 1:22 pm $189k for a 4x2 is pretty cheap especially if you are getting 2800mm ceilings. My suggestion is go and talk to the builder and ask them any questions you have. Going to another builder could take many months and $$$ if you have signed all the contracts Re: Need advicesssss 6Oct 03, 2018 1:29 pm 28 course is standard ceiling height, so unless you specified higher ceilings how is your builder ripping you off? Builder is correct in saying reworked plans will have to be resubmitted, depending on your house design it might be possible to increase some ceilings with bulkheads without resubmitting. But if you want to go higher you will be hit with extra cost & delays, switching builders a week before they go to site would most likely cost you more money & time. Re: Need advicesssss 7Oct 03, 2018 2:14 pm Sloppy $189k for a 4x2 is pretty cheap especially if you are getting 2800mm ceilings. My suggestion is go and talk to the builder and ask them any questions you have. Going to another builder could take many months and $$$ if you have signed all the contracts Hi there i am getting 28course which is 2.45m I believe, Re: Need advicesssss 8Oct 03, 2018 2:16 pm Hillsbuilds 2.4m is standard, any higher would be extra cost I believe. Do you have a very tall family? So to get the extra ceiling height but at the same budget is unlikely. Because not only will the ceiling height change, but also the doors and windows probably. And wouldn’t you have to go through council again even if you change builders? I assume the height of you roof will change too. I’m not sure what 25c garage means. Hi there As I said most all the builder will provide you 2.4meter ceiling height around the house and they ill give you 2.7meter in living area I guess, but my house has 2.4 meter all over the house which is not good right?! Re: Need advicesssss 9Oct 03, 2018 2:23 pm Huyyngg Hillsbuilds 2.4m is standard, any higher would be extra cost I believe. Do you have a very tall family? So to get the extra ceiling height but at the same budget is unlikely. Because not only will the ceiling height change, but also the doors and windows probably. And wouldn’t you have to go through council again even if you change builders? I assume the height of you roof will change too. I’m not sure what 25c garage means. Hi there As I said most all the builder will provide you 2.4meter ceiling height around the house and they ill give you 2.7meter in living area I guess, but my house has 2.4 meter all over the house which is not good right?! It’s not a given that living areas get higher ceilings. Usually extra, unless it’s a build with a higher base price to start off with. Hello It is good to have a planned bathroom reno to suit your budget and design, living for 10 years I think you need a bathtub 4 10378 Looking to start the journey of becoming an owner builder in SA. Feeling pretty (overly) confident on the building and construction details, but really struggling to find… 0 8422 I've just built 3 stairs off a landing out the back and been told by the private certifier I need hand rails sorry tried to attach a pic but couldn't mine don't have sides… 5 5720 |
