Browse Forums General Discussion 1 Sep 26, 2018 11:31 pm Hi all, Need some help with determining if these drains are built to spec. Knock-down rebuild with one of the big builders. 1. The grey stuff is powdery and some of it comes off onto my hands when I touch it. It's definitely not silicone. If you can see, at the bottom there's lots of debris and the blue line shows the hole. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 2. This one is very similar except I can't remove the cover because the builder put grout in the drain cover (Is this something I can claim?). Also, it has a large gap between the pipe and the opening Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 4726 I believe this is correct. From the picture you can see the power was put in last so the electrician knew where the water was. Really it's a common sense issue more… 4 4448 2 6449 |
