Browse Forums General Discussion 1 Sep 26, 2018 2:41 pm Hello my house is 7 years old and a couple km's from the ocean. The other day l looked under the house with the torch and l saw about 5 large long thick metal beams stretching the length of the house horizonal , with vertical metal posts underneath holding them up. l think the long horizontal beams are called the support beams, they were black and l noticed a slight of coat red rust starting to form on them. Is that something to worry about or is a bit of rust normal. They were very thick so l guess it would be hard for rust to hurt them much or am l wrong? THanks , l got a licensed building inspector to look at the rust, he said its just surface rust and it would take many years to become a problem because the beams are so… 22 28042 if l cannot get a sandblaster would a sander with sandpaper be better then a wire brush 4 7343 You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7029 |
