Browse Forums General Discussion 1 Sep 24, 2018 11:26 am Im doing mosaic decorating and lm not sure what to use to sand the glass pieces after l cut them. The pieces are varied shapes and anywhere from 5mm to 4cm in size, 4mm thick. Ive heard of everything from grinding stones to automatic glass grinders. Any ideas what would be easiest to use for regular work?? Need to remove glass panel out of concrete without wrecking the glass to get the spa room in, any recommendations on how to do that. Thank you 0 39024 What do you need them to withstand? If it's normal wear and tear, then either will do, if you want resistance to ingress then laminated would be the favourite, but only… 1 12379 |
