Hi,
Could someone confirm if I'm on the right track here.
The window was too big for the size allocated by the framing. It is the correct size window though.
So the framing was adjusted.. As you can see the lintel above the window is now no longer supported at one end. Probably the other end may not be supported too. Can't see it due to the bracing board.
This is obvious right? Thought I check before I go annoy my SS.
Kind of scray that I have a few joist above the lintel and top plates.
Thanks
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅
