I am looking for Solar system for double story house 40sq. Can anyone please recommend which company is the best and also which inventer is effective.
Thanks
Phan
Browse Forums General Discussion Re: Solar 3Sep 07, 2018 4:33 pm IamSAM Use this neutral consultant https://www.solarquotes.com.au/ Thanks IamSam Re: Solar 6Sep 11, 2018 10:10 pm Phan I am looking for Solar system for double story house 40sq. Can anyone please recommend which company is the best and also which inventer is effective. Thanks Phan I will pm you. Re: Solar 7Sep 12, 2018 12:45 pm Whirlpool's Green Tech forum is a good place to ask this question. Lots of very knowledgeable people there who are happy to help. https://forums.whirlpool.net.au/forum/143 So get 3 quotes from the solarquotes site that has been recommended, then go to Whirlpool to ask for advice. You'll have to have a pretty good idea of your usage to determine your system size. But generally a 5kW inverter (with 6.6kW of panels) is a good size, & the maximum allowable for single phase houses in most states. Getting a good quality inverter is important. If you have a well orientated unshaded roof, then a string inverter is usually the best option. Fronius is regarded as the best string inverter, & can be set up so that any excess power generation is used to heat your water (for electric storage tanks). If you have problems with shade, or a fiddly roof with many orientations, then microinverters are best, although more expensive than a string inverter. Best of luck Re: Solar 8Sep 12, 2018 6:02 pm Phan shokel1975 where are you located? Box hill South Vic I have sent you some info. Check your inbox 😀 I looked into it a few years ago and my conclusion was to just build a carport that will support panels and get a system installed separately. The company I looked at had… 1 6485 |
