Browse Forums General Discussion Re: Dispute with Metricon 3Sep 05, 2018 10:59 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Dispute with Metricon 7Sep 05, 2018 5:46 pm No, we weren't home when the plumbers inspected the water leak. When I got home, I found that the plumber covered up the trench that was dug prior to their inspection. They also covered up the digging that they did on the side of the house when they were trying to locate the leak. I was advised by the plumbing company over the phone that they would come back in the next few days to investigate further. Is it normal practice for them to cover up holes that they have dug and come back and dig it again a few days later? Re: Dispute with Metricon 9Sep 05, 2018 8:12 pm They would have covered the holes due to safety, their other option was to tape off the area. They established that there was a slow leak and other evidence also supported this. All you can really do is move it and get a plumber in to complete the investigation and fix the problem. Either the plumber or the landscaper is not telling the truth but as far as fixing it goes, the 'rock' is the fly in Metricon's ointment. The thing that would interest me is finding out how deep the pipe was buried. I assume that the 'paver' sits above ground. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Dispute with Metricon 10Sep 05, 2018 8:52 pm Thank you for your reply. Yes paver sits above ground. After I received the plumbing report, I did plan to dig to find out how deep the pipe was buried but thought I'd challenged Metricon first about the report as it did not provide compelling evidence and cause of water leak has still not been located. Spoke to VBA today and will lodge a complaint. Re: Dispute with Metricon 13Sep 06, 2018 9:20 am T123 Also the plumbing report was done by the same company that installed the pipes, not exactly and independent report. It was correct for Metricon to arrange for a plumber from their contracted plumbing company to try to identify the leak because the plumbing company warrants the work. A slow leak is usually from a fitting and to establish whether the leak is under the paver, the paver needs to be removed and the pipe examined. The onus of removing the paver and concrete is on you. If it is established that the pipe is not leaking under the paver, then Metricon need to be sent the finding/report and they then need to send out the plumbing company who did the installation to identify and repair the leak. The plumber's report indicates that the leak is most likely in the area of the paver. If the pipe was buried at a non compliant insufficient depth, this should be noted and Metricon made aware. If the landscaper has damaged the pipe, he would have to had dug down 150mm before reaching the 75mm sand cover and the sand should have alerted him to the presence of a pipe. It is hard to imagine him digging down that far but the only way you will know is to remove the paver and concrete. I would video its removal and the depth of concrete under the paver. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Dispute with Metricon 14Nov 27, 2018 2:46 pm its hard to see how its Metricon's fault after 3 years. Save yourself the headache and just fix it Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au yes it does, you've just not understood it. theres a difference. 4 5576 Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 11543 Hello All π We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8936 |
