Browse Forums General Discussion 1 Aug 23, 2018 10:49 am Re: Garage Slab question. 2Aug 23, 2018 11:33 am Slab set down is to allow garage door to close lower than your garage slab level for prevention of driven rainwater. Your driveway level will be at the lower level of the set down. This means there will be minor step which will be insignificant for your car wheels. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Garage Slab question. 3Aug 23, 2018 11:37 am building-expert Slab set down is to allow garage door to close lower than your garage slab level for prevention of driven rainwater. Your driveway level will be at the lower level of the set down. This means there will be minor step which will be insignificant for your car wheels. Thanks. Didn't thought of that!!. Is this standard? I don't see new houses having this or maybe wasn't paying attention. Cheers. It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17200 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17525 |
