Browse Forums General Discussion 1 Aug 23, 2018 9:39 am Advice please. Son has recently built with a volume builder. The energy rating hot water service is proving a nightmare. There is resonance in the pipes on cold nights, sometimes the high pitched ringing noise can go on for 10 mins, or 5-6 x o'night. It can be heard throughout the house, so his bedroom is unbearable. Being directed from builder to manufacturer to installer and around again. No one seems to want to deal with this. Has anyone had a similar experience? Do we have to disconnect the solar to escape from the noise? Thanks. Hi, I have a steel frame house which was built 2 years ago. When you are down stairs you can hear clunking noises when someone is walking around. We were told if you… 0 4457 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 13915 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20228 |
