building-expert
1 before you take on your builder you need a correct diagnosis
I am on the right track of getting a structural engineer with his|her report and then talk to the builder based everyone’s advice.
Thanks
Browse Forums General Discussion Re: Hairline Cracks and Sound from walls 21Aug 14, 2018 11:49 am building-expert 1 before you take on your builder you need a correct diagnosis I am on the right track of getting a structural engineer with his|her report and then talk to the builder based everyone’s advice. Thanks Re: Hairline Cracks and Sound from walls 22Aug 15, 2018 8:47 am dataone111 I am on the right track of getting a structural engineer with his|her report and then talk to the builder based everyone’s advice. Thanks 100%, You could have aided the engineers report, had a solution and fix to the problem if you had collected the correct Photos and Data in the first instance. Engineering FEM BIM Simulations have come a long way. OT. Please let me know if you require case studies and further info.. Goodluck Forewarned Is Forearmed. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Hairline Cracks and Sound from walls 23Aug 15, 2018 9:22 pm Mauromario . So the member told the builder you have no chance, deal with it now . Congratulations Mauromario! What a long journey to VCAT, but well deserved outcome for you and your careless builder. Was the builder given a timeline to fix the problems by VCAT? Would you mind sharing who you did use to take your slab levels? Re: Hairline Cracks and Sound from walls 24Nov 02, 2018 12:01 pm Well done mauromario,great result,fantastic seeing you give information back,you sound much more confident now. Dataone 111, why was your house sold so new, did the previous owner sell a known lemon. Most the best results from new build problems end up being won out by the party with better homework, it comes down to who has the most convincing documented evidence,good luck, Re: Hairline Cracks and Sound from walls 25Oct 01, 2020 8:41 am dataone111 were you able to find anything about this issue? Re: Hairline Cracks and Sound from walls 26Oct 01, 2020 12:11 pm Gaudi Mauromario . So the member told the builder you have no chance, deal with it now . Congratulations Mauromario! What a long journey to VCAT, but well deserved outcome for you and your careless builder. Was the builder given a timeline to fix the problems by VCAT? Would you mind sharing who you did use to take your slab levels? My levels were taken by Buratt engineering, sorry fo the very late reply been so busy with builder fixing our house with underpinning, and a full agricultural drainage system around the house. They have 90 days to do the underpinning and drainage around the house make good everything concrete path they had to cut, i got them to agree to use my concreters i didn't want the builders concreters they are useless. Then to check floor levels for 12 months and see if the slab stops moving i really hope it works, if not well they don't get let off the hook, if all this work actually stops the slab from moving builder is to come back and fix everything else frame truss heater platforms to be moved bricks to be removed and fixed and everything else that has to be fixed. Thats where we are at this moment in 2020. The spacing of the studs looks pretty large especially for a load bearing wall. 3 11117 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17198 Do you have a scope of works? If have texture on wall now, the patch will show through The standard for repair of texture is to patch, re-texture corner to corner,… 5 6914 |
