Cladding & insulation
I am trying to get a better understanding on external wall cladding installation and thermal insulation.
When an external cladding material (e.g. weather board) is directly nailed in to timber frames (which are wall wrapped), the nail will penetrate timber frames while piercing the wall wrap.
With the number of nails piercing the wall wrap (to hold cladding in place), can this somewhat decrease the wall wrap insulation/ protection ability, in preventing thermal loss and barrier against moisture etc? Is this something to be greatly concerned about? Or maybe the overall impact is negligible?
Thanks.
on a cladding wall the wall wrap is a secondary barrier to water penetration
the insulation is placed in the wall cavity between the studs
on a brick veneer the wall wrap reflects the heat into the cavity between the bricks and the wrap and acts as insulation
Hi All,
Thanks.
Thanks.
interesting scenario ! the cladding material and frame are bad conductor of heat...the impact due to nails into the frame should be negligible. overall the cladding will reduce (compared to brick) the insulation on that side as well.
Hi All,
Thanks.
Thanks.
Because we are using timber cladding, I've been reading about thermal bridging, so it made me think about this scenario.
cladding 0.55 r value
brick veneer 0.51 r value
look up r value brick veneer vs cladding
Hi aussieta, thanks for the info. Actually, my original question relates more to thermal bridging impact between timber frame and cladding. As the nail joining both materials acts as a bridge.
as opposed to an aluminium framed window which thermally bridges the gap between inside and out
If you want to avoid thermal bridging altogether, then you'll need to look at either using a different construction than timber frame (e.g. ICF, SIPS) or using an insulating external cladding instead of weatherboard (e.g. EPS). Again, some or all of these options may be overkill for you, depending upon your particular circumstances.
Thanks.
Thanks.
The surface area of each nail head and impact (Conductance & Transfer) is negligible
wood is a poor conductor or energy
there is no need to prove this with science, math & FEM illustration/simulation
OT, Here is a simulation example for "Shaded & Unshaded Esky with drinks
which is used to predict beer temperature in an esky at the beach... BTW the beer temp difference in WA during summer is 2 deg.. LOL no need for an app. Common sense should tell you that you don't need a better esky design
17
Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a…
30/05/2023
3
The spacing of the studs looks pretty large especially for a load bearing wall.
4/10/2023
3
Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters…
