Browse Forums General Discussion 1 Jul 29, 2018 7:00 pm Hi everyone, I'm new to this forum. I currently have a separate double garage with a concrete floor, limestone walls with brick on top which is semi submerged, as can be seen in the pictures. What I want to do is convert at least one side of the garage into a clean workshop space with a timber floor and timber paneled walls, including replacing one of the roller doors with a wall and window. So basically building a timber room within the garage space. My problem is the damp/water seeping through the limestone walls as they are below the ground level and are very crumbly. So the garage is always damp and sandy. I've had a structural engineer check it over and they said it was structurally sound. How would I go about waterproofing the space? Would the garage need to be waterproofed or just the timber room within the space. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Any advice would be welcome. Cheers::praying:: Re: Waterproofing semi submerged limestone garage walls 2Jul 30, 2018 2:29 pm Wow ! You may well have to dig down outside and water-proof membrane. Then an ag drain as well. Floor doesn't look that good either. Hi I live in a 100yr old semi and my neighbour added an additional floor last yr and our architect has advised that we can knock down our semi and build a free-standing… 0 37709 Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 25163 |
