Browse Forums General Discussion 1 Jul 26, 2018 11:04 pm Hi All, Searched through the forums, however I haven't seen a clear explanation re: Building Surveyor vs. Building Inspector. My planning permit (with conditions) has been issued. Within the documentation, Council advised me to check with a Building Surveyor to confirm if a building permit is required. Since I am building a new home, for sure, a building permit is required. From what I have read and understood so far (please correct me if I have misunderstood). A Building Surveyor will issue the building permit, on condition my building design/ plans meet regulations/ code and is compliant. In addition, it seems their duties extends throughout the construction process (e.g. conduct building inspections). They can also issue occupancy permit too, if the completed home meets regulations, codes, etc. Then there is the Building Inspector, who will purely inspect construction process at various stages. It seems the Building Inspector role is more specialised when it comes to strictly monitoring and enforcing building codes, regulations etc. So both Building Surveyor and Building Inspector can carry out inspections, but the Building Inspector will conduct a more thorough job? Would love to hear your thoughts and experiences. Regards. Re: Building Surveyor vs. Building Inspector 2Jul 27, 2018 8:05 am Yes your understanding is good. Building Surveyors assess whether the building will comply, then issue building permit. Building inspectors carry out mandatory inspections to ensure health safety and amenity of the building as constructed. Educational entry level for Building Surveyors is higher. Usually BS are too busy and get BI for inspections and it is also a lot cheaper for them to do so. Don't forget that mandatory inspections are not quality inspections, BI don't ensure builder is following drawings in all respects and do not ensure conformance with the building contract. So if builder makes substitutions ie changes specified building material for a cheaper one neither BS or BI will be interested(you loose). Since there is no mandatory QA and contract conformance, for your own protection you should pay for your own. Your best bet is to engage your own building consultant to look over your build at critical stages: pre contract, pre slab, frame, pre plaster, and pre final. Allow about 3K and its less than the cost of hair replacement. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Building Surveyor vs. Building Inspector 4Jul 28, 2018 8:42 am meowys I'll still request the services of both (independent) BS and BI. The BS employs the BI. In Victoria, it is legislated that the new home buyer appoints the BS. See the VBA website for details. As per building expert's succinct post, you can also appoint your own independent building consultant to undertake stage inspections. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. I would send it to the certifier who is technically your representative and working on your behalf not the builder's 1 2267 I do enjoy the drama:-D In his latest two videos he has started bringing security guards to site, I am waiting for the punch on to begin lol 6 45547 Adam Baines Grad Cert Bldg Surv / Grad Dip Bldg Surv / MSAAPA Accredited Building Professional APB20210035 Builders Lic 183023 Pest Control Lic 84868 Ph 0412202336 PO… 3 46834 |
