Browse Forums General Discussion 1 Jun 21, 2018 4:25 pm House was built two and a half years ago. Found out today that the water pressure is 620kPa. It would cost over $400 to install a valve. Is this not the builder's responsibility to ensure that the water pressure be maintained at 500 or below kPa at handling over the keys? All warranties relating to tap wares are void. Is the original builder obliged to adjust the pressure as per regulation? Re: Water mains pressure exceed 500 KpA 3Jun 21, 2018 6:35 pm wally97 House was built two and a half years ago. Found out today that the water pressure is 620kPa. It would cost over $400 to install a valve. Is there a pressure limiting valve fitted? There should be. If not, contact the builder because you have paid for one. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Water mains pressure exceed 500 KpA 4Jun 22, 2018 4:03 pm How do I check if there is a pressure limiting valve fitted? The plumber came, tested it and asked me if I would have a 'valve' installed for $450 on site or $575 if he comes another time. So, I suppose it is not there, otherwise why would the plumber put in a second valve. I am a senior on a pension and would need to save up for the valve. If I can be sure the valve was not fitted then I would certainly contact the builder. Re: Water mains pressure exceed 500 KpA 5Jun 22, 2018 4:28 pm Didn't the plumber tell you that you had a valve or not? It would be unusual for one to fail. Just Google so you can see what it looks like. They are invariably fitted near the meter. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. if it's the look that you're not happy with, the easiest option would probably be to spray paint it all into the same color as the walls so it blends in. there might not… 3 4250 Staircases and sausages. Should thou wish to keep thy palate sweet for sausages, avert thine eyes from their crafting. 14 4758 |
