Browse Forums General Discussion 1 Jun 21, 2018 3:47 pm Hi all, Does anyone come across the variation in contour survey compared to original Landcom Designer contour plans before registration.As i have bought land in macarthur heights stage 4 ,before registration we had 3m fall and now after registration builder did contour survey and according to that there is 4m fall. So please pour in your suggestion and recommendations who has pass through such situation. Re: home building in macarthur heights with fall 2Jul 16, 2018 4:01 pm Hi there - did you end up finding a way forward to your issue? Which builder are you going with? We are also having trouble with site costs with a 3m fall on our stage 4 block. Thank you Splashers. Tomorrow I might check if I can get a few packs of 300x300 in the same tile finish. It may be good to use these could in the shower recesses. I'm not… 4 4691 I've got a challenge here. Background is the builder has cut too deep for the slab and the slab is now below the very substantial retaining wall. It's failed occupancy… 0 18402 AS4654.2-2012 External Membranes it is "Informative" but if you get water ingress your insurance assessor will go to this straight away and if not achieved, they will deny… 9 1920 |
