Browse Forums General Discussion 1 Jun 18, 2018 10:05 pm Good evening, I.was trying to fix a leaking bath tap yesterday. I initially thought it was just a simple washer change but found out it is the seat crack and it is nylon white seat with a special cone shape washer. The bunnings guy said it might has been repaired once and this nylon seat was the later added. Does anyone know what kind of seat it is and whther I can pull it out to replace with a brass seat by using a seat repair kit? Many thanks in advance. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: A Special bath tap seat? 2Jun 19, 2018 6:13 pm i used ceramic bath sets which does not use the original seat, the whole thing is in the tap body https://www.bunnings.com.au/mondella-ch ... t_p5002774 Iām loving the potential versatility and practicality of a bench seat in a shower. Anyone had one of these done recently? Not sure if they are straight forward and easy… 0 763 that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink 1 7398 7 5144 |
