Browse Forums General Discussion 1 Jun 18, 2018 12:58 pm Just a quick question. We have had our new place built . We used square set cornice throughout the house. Hand over was about 9months ago. I noticed a few hairline cracks near the cornice here and there, which the builder is happy to fix but I'm just wondering if this is normal and is square set cornice more prone to cracking in general, in comparison to standard 90 cove cornice? Thanks Re: Is square set cornice more prone to cracking? 2Jun 19, 2018 10:47 pm My builder said it’s prone to cracking with settlement, mainly in corners. A few is probably standard. If you had a cove plaster cornice installed it would all be hidden below. Good your builder is fixing 9 months in. Re: Is square set cornice more prone to cracking? 3Jun 20, 2018 10:24 pm volmix Just a quick question. We have had our new place built . We used square set cornice throughout the house. Hand over was about 9months ago. I noticed a few hairline cracks near the cornice here and there, which the builder is happy to fix but I'm just wondering if this is normal and is square set cornice more prone to cracking in general, in comparison to standard 90 cove cornice? Thanks Yes it is and is more visible than standard cornices.If there is some movement in your foundations or frame it can be more noticeable with square set.I would recommend it not to be used in areas with highly reactive soils but builders don't care as long as it looks good in the display home and gets them a sale . Re: Is square set cornice more prone to cracking? 4Jun 21, 2018 12:50 pm insider I would recommend it not to be used in areas with highly reactive soils but builders don't care as long as it looks good in the display home and gets them a sale . Aesthetics subjugating function. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Depends... Brick veneer required the window to be attached to the house frame, this is usually achieved by screwing through the timber reveal into the frame. There are… 1 7441 The photo is not really clear but to me it looks like twist in the cornice. Slight anticlockwise rotation at the top of the cornice and slightly clockwise at bottom should… 8 8467 1 6559 |
