Browse Forums General Discussion Re: Which side of block will receive more sunlight 2May 17, 2018 9:40 pm Go for the block with the living areas facing north (is that block B?) Re: Which side of block will receive more sunlight 5May 17, 2018 11:02 pm Yep, definitely go with block B. North-to-rear is much better than north-to-street. Re: Which side of block will receive more sunlight 6May 18, 2018 2:47 pm Yep, as others have stated, Block B is the best, as it's north-to-rear. You'll have nice sunny living areas at the back of your home, & a sunny back yard. Block A, north-to-street is the worst orientation you can have. This is because a large double garage there will receive all the sun, while the inside of the house will be dark, & cold in winter. The backyard will also receive little sunshine in winter. Put whichever room you want to receive the most early morning sun in the NE corner, presumably the kitchen/dining. Read more about orientating your house correctly here, http://yourhome.gov.au/passive-design/orientation Hi HomeOne, I'm in the midst of landscaping a cat run down the side of my house, and the recent rains have me wondering if I need to install some sort of drainage. I've… 0 12283 My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 6927 Hey everyone Not for me or anyone I know, just generally interested. For a single allotment house, are you allowed to take the fence on both sides of your house and… 0 20889 |
