What do I look for in quality double glazed stacker doors? Quality in terms of glass, aluminium frame (eg thickness and thermal break) tracking system, maintenance and after sales service. I am considering rylock, yonkor, jolong, shield (Upton) and carinya products at this stage.
Thanks
Stacker doors good vs bad
Thanks
Depending on style they can take up quite a bit of room when open. We have wooden cedar sliders which work very well - and don't jut out.
1
What do you need them to withstand? If it's normal wear and tear, then either will do, if you want resistance to ingress then laminated would be the favourite, but only…
11/10/2023
6
Sure looks like the type of track that I fitted to my house. My supplier said that the underside has a tray which drains to the front. They cut vertical slots in it. So as…
15/08/2023
1
You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not…
