Browse Forums General Discussion Re: Brick internal wall 3May 11, 2018 11:18 am Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I want to widen the gap to 300mm from each corner. All internal walls are single brick. I had to cut out and and repair a water damaged area in the plasterboard ceiling and noticed large metal beams below the concrete. It's been suggested that when they built homes like this, the internal wall would have been built after the upper slab was done and therefore is not a supporting wall. Someone suggested I cut out a bit of the cornice and see if there is a gap at the top of the brick wall. Re: Brick internal wall 4May 11, 2018 4:37 pm Silly question but - you don't have the plans ? We always keep them and hand them on when we move. Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks 3 7944 3 10216 Sorry, don't know costs, but there are a couple of very important principles you need to get right (and now) .... (1) never agree to any "upgrade" unless you first know… 5 6852 |
