Building ForumGeneral Discussion
Storm Water with Fairmont
Hi everyone,
A bit confused about storm water and what is included it says on the quote “storm water (to kerb) Hse<170m2, incl. flex connections, Bldr’s std - (Allowance) - $2200. Anyone had any experience with this. Does this mean that all the storm water is included?
This is with Fairmont.
Thanks,
Katfife.
KatFife
Then you may need to connect to the Council's stormwater
Phone your Council and Ask the costs?
BTW you might want to also check Storm water Invert & FFls
Storm water drainage
Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new…
17/01/2024
1
Storm water extension?
General Discussion
If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a…
7/04/2024
2
Storm water overflow pit, is this right?
Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished…
