Browse Forums General Discussion 1 May 06, 2018 9:19 am Re: Should the builder fill and level up the ditch they dug? 2May 08, 2018 6:03 pm Short answer, no they shouldn't. Long answer is they're probably expecting you to do landscaping immediately and so haven't bothered to fill the ditch or re bury the fence footing. If you're getting a landscaper in then they'll fix it, if you're doing your own landscaping then get shoveling. If you're not doing either then you will have an unlandscaped yard with dirt, maybe a ditch and an area that looks like it needs a little retaining wall. If you mention it to them maybe they will be nice and dump some dirt in there. Re: Should the builder fill and level up the ditch they dug? 3May 09, 2018 9:21 am Short answer - no - they couldn't be bothered. Long answer - they think you'll do it anyway if they don't. Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 15447 i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 15822 Hi All, I just wanted to close this topic out with an update. So we ended up agreeing to a number with the insurance company, and after an extensive amount of hand… 8 23348 |
