Browse Forums General Discussion 1 Apr 28, 2018 11:08 pm Re: Split level build holes in roof 2Apr 30, 2018 10:01 am That should definitely be covered but judging by the exposed nails the job is probably not finished. It looks a bit unusual but that kind of thing is a kit home special, if this is a kit home then it's to be expected. Should definitely be covered by some sort of flashing otherwise you'll end up with all kinds of nests in your roof space. Re: Split level build holes in roof 3May 03, 2018 8:28 am Hi, I just heard back from the builders and they have said they have ordered some flashing to cover the whole. I still think they are short one brick and should have extended the brick just by one. They have also advised the exposed surface is called Hardiflex which is a lightweight infill. I’ll have to google Hardiflex to understand what it is exactly. Thanks for all your help and advice. Re: Split level build holes in roof 4May 03, 2018 8:28 am Hi, I just heard back from the builders and they have said they have ordered some flashing to cover the whole. I still think they are short one brick and should have extended the brick just by one. They have also advised the exposed surface is called Hardiflex which is a lightweight infill. I’ll have to google Hardiflex to understand what it is exactly. Thanks for all your help and advice. Move your linen into laundry and access laundry from your present linen space 1 8013 it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7086 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 5455 |
