Browse Forums General Discussion Re: FRONT HOUSE SETBACK DISPENSATIONS ? 2Apr 28, 2018 9:41 pm Ours is 2 storey, and you need to understand what an allowable encroachment on a setback is, basically, you can have a porch or verandah in front of the front wall of your house as an allowable encroachment, there is a height restriction on allowable encroachments (I think 3m), so you cannot have a balcony as an allowable encroachment. We had to remove most of the balcony on our design. If you want you can try and and put in an application for report and consent with your local council, but I would speak to them first to see if it is likely they may consider it as it takes time and a few hundred dollars. Are you set on your house design with the balcony? You could ask the builder to remove the balcony from the facade, or you could look for a new house design. The shallowest 2 storey house designs I found from builders that built in my part of Victoria were the Metricon Trentham or Winchester, Simonds Stanten, 8homes Java and Mode, Dennis family Sapphire and Topaz. All of this info relates to Vic. Re: FRONT HOUSE SETBACK DISPENSATIONS ? 3Apr 30, 2018 3:11 pm Hi, Thanks for your good advised .my home plan is Glendale 45 and facade is isla facade.I saw many people build less then 4 m front the footpath.I talked with builder but they said 4 M.Actually they try make easy their job they do not care because they are not living in that home.An by the way what is role of building surveyor which builder appoint for our job .plz help me. Re: FRONT HOUSE SETBACK DISPENSATIONS ? 4Apr 30, 2018 10:56 pm Is it one storey or 2 storey built less than 4m from the footpath? If it is single storey it is ok if the porch is less than 4m. If it is 2 storey there are 2 things that could have happened. 1. The owner applied for dispensation and it was approved 2. A private building surveyor has signed the building permit even though it does not meet regulations - this is probably more common than you would think. In my area the council recently changed the zoning, we did the 'correct' thing, applied for dispensation, and got our application declined by the council. However, there are a lot of houses being built that do not meet the new regulations that have had private building surveyors issue building permits, and I queried with the council, these builds do not have dispensation. In theory, the council could ask people to tear down the non compliant parts of their building. In reality the council does not have the resources to check all builds and are only likely to investigate if they get a complaint. The building surveyor issues the building permit and occupancy certificate. They are supposed to make sure the building is compliant with relevant building codes. I would still hire a private building inspector to check the quality of the work. Re: FRONT HOUSE SETBACK DISPENSATIONS ? 5May 01, 2018 9:48 pm https://www.consumer.vic.gov.au/housing ... lding-team building surveyor – to check building work meets the MINIMUM STANDARDS of the building regulations. Make sure you appoint only one building surveyor. From 1 September 2016, builders are not permitted to appoint a building surveyor on your behalf. For more information, view our Building plans and permits page. You can find a surveyor registered with the Victorian Building Authority (VBA) by visiting the Practitioner Search page on the VBA website. You may also choose to engage an independent building consultant(often called inspector) who can make sure the plans suit your specific needs and to check the quality of work during construction. A competent consultant will also be able to provide the building lawyer with a technical understanding of the building project. Search for building consultants online or in the telephone directory. Check they are qualified and experienced in the type of work you are undertaking (for example, two-storey timber-framed construction), and have insurance that will cover you for the type of work they are doing. Inspectors/building consultants aren’t necessarily registered so do research and choose someone with many years experience in building and/or qualifications. Use an inspector to have someone helping you check quality and standards are met like walls that are straight and fire standards that are met. Re: FRONT HOUSE SETBACK DISPENSATIONS ? 6May 01, 2018 9:51 pm Re: set back https://www.planning.vic.gov.au/__data/ ... e-2015.pdf Have you looked at the council minimum setbacks for your land- I think depends on zoning and what setback your neighbors have. I’d suggest speaking with the townplanner or draftsman that’s been involved in planning your build for advice Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 15778 Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8463 This was on google. Development controls 2.3.1 Front setback D1 New buildings within residential areas shall adhere to a front building line, which is 5.5-6m to the… 1 3677 |
