Browse Forums General Discussion 1 Apr 21, 2018 6:07 pm Hi All, Want to build a vertical timber screen at home (merbau 42 x 19’s) Plan was to screw the battens to the joists. However, interested to know if the joists should be screwed or nailed to the posts? Interested in thought & opinions. Thanks Re: Timber screen fixings 4Apr 23, 2018 11:17 am Big screws or gal bolts! It's probably going to weigh a fair bit! Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 16005 You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of… 1 7133 2 4518 |
