Browse Forums General Discussion Re: Slab heave is alive and well, watch out. 62May 23, 2018 12:19 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Slab heave is alive and well, watch out. 66May 26, 2018 11:34 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Slab heave is alive and well, watch out. 71May 26, 2018 1:46 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Slab heave is alive and well, watch out. 77May 27, 2018 12:50 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Slab heave is alive and well, watch out. 79May 27, 2018 10:21 am Joker Sorry story is gone. Maybe only I can see the Facebook post as I have recently followed VBAG. Maybe try following VBAG on Facebook to read some of the posts including that one about geotech. https://m.facebook.com/vicbuildingactiongroup/ You can always unfollow after you’ve looked at some of the posts if you don’t agree or support messages they area sharing. Slab heave is alive and well, watch out. 80May 27, 2018 10:35 am I’ve read of stories where construction lawyers have worked as lawyers for builders in the past denying claims and may have relationships on other side or may not have some of the skills required. learn more about the lawyer and their past experiences at VCAT if you can. Then you can be informed. Lawyers also do like to line up all the dots to have all the information they need, so Mauromario yours may just be doing that and may be just going through the process. The legal world is another new territory. So good to ask all the questions you have so you can have confidence in them. I’d ask is case still strong enough without your photo evidence if can’t submit as evidence. If not should the story stay quiet? if your builder is a volume builder do they really want that negative publicity? You could offer your builder that you can host alternative display home tours at your house for free. i wouldn't be worried, you'll definitely miss something, no matter how many times you review. we've spent close to 5 months ensuring everything got reflected in the… 5 9455 It's possible but a soak well is usually much larger. Your 'soak well' only holds 424 litres when full. What is your soil type? Soak wells need sandy soils. 10 6192 Finally got the Soakwell at my house sucked out. Now I’m looking for ideas on how to hide it as it’s a bit of an eye sore. I’m thinking I’d like to turf over the… 0 1561 |
