Browse Forums General Discussion 1 Apr 01, 2018 6:31 am Am looking at sealing the garage floor (New Build). The problem I am facing is that all products seem to instruct you to give the floor pressure washing but the garage is fully lined with gyprock and architraves and I don't want to water damage the new walls. Is there any way or product that I can use to prepare the floor ? Any info regarding products and techniques greatly appreciated Colin Re: Garage Floor Painting 2Apr 02, 2018 2:05 pm Wny paint? Paint almost invariably lifts and then you've got to patch. Floor tiles like these http://www.garagestorageworld.com.au/pr ... -flooring/ are great If you spill paint or something on a tile just replace that tile isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17525 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16554 Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 5024 |
